Wow Joe....you have PCM files to flash an unflashable car?
Are you sure you aren't talking an older OBD1 or a later "Flashable" ecu????
Right from the Hondata website:
Integra: "The stock ECU cannot be used, and must be swapped...."
Civic Si: "The stock ECU cannot be used, and must be swapped...."
If you do have something that will work - you've outdone Hondata and the rest of the Honda Tuners. Well done!!!!!!
Joel
http://www.RaceLabz.com
570-655-7272
