HS mini setup?
Last post 02-08-2010, 8:12 PM by racnmni. 18 replies.
Page 1 of 2 (19 items)   1 2 Next >
  •  01-11-2010, 11:10 AM 398579
    HS mini setup?
    i am just curious where to start with the setup on a 08 HS mini. can anyone give me a toe setting starting point? what about tire pressures on both v710 & a6? thanks.
  •  01-11-2010, 11:17 AM 398580 in reply to 398579
    Re: HS mini setup?
    max camber front
    min camber rear
    0 toe rear
    0 to 1/8 toe out in front
    I ran the 710s  45 front, 36 rear, never ran the A6 on the Cooper
    Keith
    www.chaserace.com
    www.tightntidyracing.com
    www.vorschlag.com
  •  01-15-2010, 6:46 PM 399103 in reply to 398580
    Re: HS mini setup?
    Hoosiers 40-42 ft, 48-52 rear depending on surface and shock setup. And they are faster than the K tire : P Dont know if you have any already, but I am selling my shocks fresh off the 09 National Champion GS Mini. Front and rear D/A custom valved Koni's. Rebuilt in 08, won Nats 09, trailered home, then taken off the car one autocross later.  Also selling some SSR's as well. Getting ready to list up in the for sale section this weekend.  Jeff Jacobs and I run almost the exact same setup, and he was one of the fastest HS cars in the country. (R56 Cooper)
    Tony Savini
    2009 GS National Champion
    2005 Mini Cooper S- retired
    1999 Corvette FRC
    AS here I come!
  •  01-16-2010, 3:56 AM 399125 in reply to 399103
    Re: HS mini setup?
    racnmni:
    Having been Jeff's tire warmer, I will attest to that one of the easiest HS cars I've ever driven.
  •  01-16-2010, 5:53 AM 399126 in reply to 399103
    Re: HS mini setup?
    motoring:
    45 front, 36 rear,
    racnmni:
    Very interesting.
  •  01-24-2010, 5:47 PM 400118 in reply to 399126
    Re: HS mini setup?
    710's vs Hoosiers.  Pressures are going to be quite different.
    Tony Savini
    1999 Corvette FRC
    AS here I come!
  •  01-25-2010, 11:46 AM 400169 in reply to 398580
    Re: HS mini setup?
    motoring:
    0 toe rear
    I assume that's with adjustable shocks that allow you to stiffen up the rear suspension?
    With stock shocks, I needed maximum toe out (a bit over 1/4") to get decent rotation with my MINI.
    Steve Garnjobst
    #75 DP
    Featuring 100 less horsepower for 2010!
    http://www.mnautox.com/
  •  01-26-2010, 5:55 PM 400365 in reply to 400169
    Re: HS mini setup?
    On my GS Mini, here are my pressures. I too have essentially the same shock build as Tony and Jeff.
    In my testing, the Hoosier was about .5 sec faster than the Kumho, but the Kumho got twice as many runs before cording.
    Kumho: 42F-55R
    Hoosier:  35F-38R
    Greg Reno
    '06 Mini Cooper S
    #36 GS
  •  01-27-2010, 4:05 PM 400487 in reply to 398579
    Re: HS mini setup?
    You might wish to browse around in here as well.
    http://www.northamericanmotoring.com/forums/h-stock-53/
  •  02-02-2010, 2:38 PM 401255 in reply to 400487
    Re: HS mini setup?
    Well FWIW...when we ran karter's 06 Mini...we had the Chiles valved konis on it...minimum rear camber and 1/8" toe out in the rear. 1/8" toe out up front and max camber (I don't even think it was adjustable).
    It worked VERY well. The toe out in the rear and taking the camber down to like -0.4 REALLY helped the car to rotate.
    David Hedderick
    Pearland (Houston), TX
    http://www.hyperfuels.com
    09 VW Jetta TDI SSC racer
    08 Mazda 3s
  •  02-04-2010, 8:05 PM 401573 in reply to 401255
    Re: HS mini setup?
    I never ran toe out in the rear, but taking out as much rear camber as possible makes a huge difference in the car.
    Tony Savini
    1999 Corvette FRC
    AS here I come!
  •  02-05-2010, 5:23 PM 401641 in reply to 400365
    • ron is not online. Last active: 03/19/2010, 5:51 PM ron
    • Top 200 Contributor
    • Joined on 03-03-2003
    • Topeka Ks. U.S.
    • Posts 463
    • Points 7,605
    Re: HS mini setup?
    Holly smokes Greg, you forgot what pressures you normally run AGAIN. Normal pressures on the the A6's for use were 41 front and 56-58 rear.
    Ron Williams
    Multi-time national champion
  •  02-05-2010, 5:27 PM 401642 in reply to 401641
    • Topeka Ks. U.S.
    • Posts 463
    • Points 7,605
    Re: HS mini setup?
    On the kumhos we ran 46 front and 56 rear and we always ran 1/8th total toe out in the front and back. Very little camber in the rear always made the car very twitchy during normal driving. If you want a good comprimise set the rear at -1* camber, gives you good tire wear on the street with good manners on the street and the track.
    Ron Williams
  •  02-06-2010, 8:20 PM 401721 in reply to 401642
    Re: HS mini setup?
    Depends on what you call 'normal' driving... ; )
    Tony Savini
    1999 Corvette FRC
    AS here I come!
  •  02-07-2010, 5:25 AM 401738 in reply to 401721
    Re: HS mini setup?
    what about fuel load? do mini's starve when low on fuel?
