Blytheville Pro Solo Index Results
Last post 06-22-2009, 10:53 AM by Dave Schotz. 26 replies.
06-08-2009, 7:27 AM |
rtp.rick
Joined on 05-11-2001
O'Fallon, MO USA
Posts 1,339
Points 18,025
Attached is a PDF of the Final Pro Solo Index Results. I will post Left & Right Results in the following two posts. These three sets of results use the Pro Solo Index Factors, NOT the PAX/RTP factors.
H's & K's, Rick Ruth
EDIT: I have replaced all of the PDFs in these posts at about 8:52am CST. There were, apparently, some errors in the original posts. Hopefully, I have corrected them.
EDIT 2: I have, again, replaced all of the PDFs (at 1:52pm CST). I had Erik Strelnieks Actual Time computed incorrectly. Gee, I hope that's all.
06-08-2009, 7:28 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,339
Points 18,025
Re: Blytheville Pro Solo Index Results
Attached is a PDF of the Left Side Pro Solo Index Results.
EDIT 3: I posted the correct list at 4:18am CST on 6/9/09. Sorry.
06-08-2009, 7:30 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,339
Points 18,025
Attached is a PDF of the Right Side Pro Solo Index Results.
06-08-2009, 7:32 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,339
Points 18,025
Attached is a PDF of the Final Pro Solo Index Results using the PAX/RTP Index factors. I will post Left and Right side results using these factor in the following two posts.
06-08-2009, 7:33 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,339
Points 18,025
Attached is a PDF of the Left Side Pro Solo Index Results using the PAX/RTP Index factors.
06-08-2009, 7:34 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,339
Points 18,025
Attached is a PDF of the Right Side Pro Solo Index Results using the PAX/RTP Index factors.
06-08-2009, 8:41 AM |
ron
Joined on 03-03-2003
Topeka Ks. U.S.
Posts 463
Points 7,605
You might want to check your figures again, The majority of your index results are wrong becouse the actual times that were user to make it are wrong. Your origional post figures are correct actual times.
Ron Williams Multi-time national champion
06-08-2009, 9:55 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,339
Points 18,025
Hopefully, I have corrected the errors in my original PDFs. Thanks, Ron, for the heads-up.
06-08-2009, 11:40 AM |
OasisTan
Joined on 06-23-2004
Blue Springs, MO
Posts 1,030
Points 12,515
Thanks Rick! Once again, I like the RTP results a good bit better. ;-)
2006 GS National Champion 2007 GS National Champion....Runner up lol 2008 GS National Champion 2009 BSP National Champion....Runner up, lol again, although, not so funny lol
06-08-2009, 12:03 PM |
SHill
Joined on 03-19-2007
Kansas City
Posts 98
Points 1,675
OasisTan:Thanks Rick! Once again, I like the RTP results a good bit better. ;-)
No way... PRO index is MUCH MUCH better!
Shawn Hill 07 Mini Cooper HS Kansas City Region SCCA
06-08-2009, 12:18 PM |
RaceChickSolo2
Joined on 08-12-2005
Posts 14
Points 310
Something still seems a little off, at least in the Pro Index results. Erik Strelnieks in shown as sharing 123rd with Lori Gill after winning SSM?
Christine Berry 2006 Mitsubishi Evo RS, BSP
06-08-2009, 2:26 PM |
rtp.rick
O'Fallon, MO USA
Posts 1,339
Points 18,025
RaceChickSolo2:Something still seems a little off, at least in the Pro Index results. Erik Strelnieks in shown as sharing 123rd with Lori Gill after winning SSM?
I'll look at it again.
EDIT: I have, again, replaced all of the PDFs (at 1:52pm CST). I had Erik Strelnieks Actual Time computed incorrectly (it shouldn't have been computed at all). Gee, I hope that's all. Thanks Christine.
06-08-2009, 9:43 PM |
ron
Topeka Ks. U.S.
Posts 463
Points 7,605
I got to say that the HS change is wrong in so many levels, This particular pro had no long straight for the faster cars to take advantage of and HS ended up doing ok in the pro index. But... your rtp index places the top two drivers in the pro index way below many other classes that had multiple drivers in higher spots. SS had three above the top HS driver. I would agree HS should have been changed slightly, but, about half of what it actually did change. Again multiple drivers at nationals per class were ahead of the top drivers in H and yet the index changed. Now H cars don't have a chance in haiti's to win the index. Just an opinion of course.
Thanks for all you do Rick
06-09-2009, 3:11 AM |
Davard
Joined on 12-30-2000
Topeka, KS
Posts 1,258
Points 19,110
OK, now the left Pro index is actually the left PAX/RTP.
David Avard 89 Honda Civic Si black (STS) 07 Mazda 3s (HS?)
06-09-2009, 5:19 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,339
Points 18,025
Davard:OK, now the left Pro index is actually the left PAX/RTP.
Geesh. I posted the correct list at 4:18am CST on 6/9/09. Thanks, David.
Page 1 of 2 (27 items)
1
