STS2 CRX alignment recommendations?
Last post 05-14-2008, 9:46 PM by ibaker. 59 replies.
04-02-2008, 11:20 PM |
accordHS22
Joined on 08-15-2005
Morgantown, WV
Posts 52
Points 940
195/50/15 RE-01Rs shaved to 4/32nd
Ran 37 psi fronts and 34 psi rears Listed setup below is what I ran when I was running the RT-615s -3 degrees and 0 toe up front -2.5 degrees and 0 toe in the rear Koni DAs on both end with 430 lb fronts and 500 lb rears Stock Si front bar and non adjustable ST rear bar After the first event it seems like the car would feel better with a little less camber. My co-driver and I both agreed we weren't getting as much traction as we could possibly have. It was a relatively cold day, so it could be a matter of paranoia. Any thoughts would be appreciated.
The Brown Sean 1988 Honda CRX Si (STS2 #48) Not DFL at DC!
04-03-2008, 8:20 AM |
Crosser1
Joined on 02-24-2002
Austin, TX
Posts 196
Points 3,010
Re: STS2 CRX alignment recommendations?
Before you make any wholesale changes I would wait until you have run on a warmer day...the 'stones definitely do not like the cold.
04-03-2008, 10:50 AM |
glagola1
Joined on 04-08-2004
Atlanta
Posts 204
Points 2,340
Take off that front bar. You don't need it... Sure, it makes the car easier to drive but it's slower since you can't use much gas on exit with out wheelspin and push is the devil.
You're alignment looks good... maybe a tad too much front camber.
Pressures seem right.
My S2000 is totally pissed it's not allowed a place to play in ST.
04-03-2008, 12:11 PM |
accordHS22
Morgantown, WV
Posts 52
Points 940
I'll try no bar this weekend since its a test day, so much for spending all that money last summer and getting new front sway bar bushings. *laughs* I think you guys are right about the cold weather, hand test and pryometer readings were extremely low on the tires. My notes said ambient temperature was in the 44-45 range.
04-03-2008, 12:38 PM |
Crosser1
Austin, TX
Posts 196
Points 3,010
Yeah, I was running an evo school in the Miata last weekend in 55-65 deg weather with no sun and windy conditions. Even at the warmest of the day doing back to back to back runs, the stones were not at optumim temp. They were just starting to get happy, then it got cooler and grip dropped again.
04-03-2008, 2:08 PM |
DMcKnight
Joined on 11-02-2003
Central Texas
Posts 369
Points 5,565
Sean, I'm running 0 toe all around as well, with -2.8f and -2.1r
'91 CRX Si (STS2)
04-03-2008, 2:13 PM |
accordHS22
Morgantown, WV
Posts 52
Points 940
David: we have very similar setups. I think we both posted ours on roadrace-autox.com once a while back. I'll try no bar and hopefully the warmer weather this weekend gives me a little more time to get used to the 'stones.
04-08-2008, 1:10 AM |
TractionCircle
Joined on 02-26-2007
South FL
Posts 21
Points 290
We ran the following:
Front: -2.5 camber, 1/8" toe out, no front bar, 36psi
Rear: -2 camber, 1/16" toe in, st adj bar on middle setting, 31psi
The combination of no front bar and the little bit of toe in in the rear really made the car controllable.
YMMV
Jay Ruggles #97 STS2 CRX "Lil Evil"
04-08-2008, 10:46 AM |
glagola1
Atlanta
Posts 204
Points 2,340
TractionCircle:
YMMV
Hey Jason, if you're running 15" B-stones that set up sounds pretty damn good.... spring rates? :)
04-08-2008, 12:56 PM |
TractionCircle
South FL
Posts 21
Points 290
Hey Matt, to be honest I don't really remember what the rates were. It was Darrin's car and they kinda came with it. I wanna say 450/600 but I think I am making that up.
Yeah, that was on the 15" stones...we never had the money to experiment with the 16's. It's a moot point now since that car is in Iowa somewhere :)
04-08-2008, 2:08 PM |
SoloTiresdotCom
Joined on 04-30-2005
Jacksonville, FL
Posts 322
Points 3,855
We had 1/8" toe out at Nats...don't you remember, Jay?? -MK
04-08-2008, 3:49 PM |
TractionCircle
South FL
Posts 21
Points 290
Yeah, isn't that what I said? On a side note, I may be calling you about some setup tips on my Z.....
04-08-2008, 6:02 PM |
SoloTiresdotCom
Jacksonville, FL
Posts 322
Points 3,855
We'll see if I return that call... -MK
04-09-2008, 7:31 AM |
rotation
Joined on 03-20-2002
Keokuk, IA, USA
Posts 20
Points 295
Well, I managed to smack a deer in 'Lil Evil heading to a T&T in Des Moines... guess the name fits.
So, my question for those with more seat time in an STS2 CRX (which is pretty much anyone who has one), do you recommend no front bar for all conditions, low/high grip surface, temp, etc.? Maybe I was not getting on the power early enough, no push and no problem putting power down. Most imrpovement would come from left foot braking for smoother transition of front/rear weight when going through some faster off-sets.
I attended a local school this year with an HF bar and the car rotated very well (cool 45F) and was planning to disconnect it along with a few other adjustments at the T&T, but bambi altered those plans and the racing budget. A replacement hood, headlight, radiator, and windshield are on order.
Steve
Steve Curran '89 CRX Si STS2 "Zippy"
04-09-2008, 9:38 AM |
TractionCircle
South FL
Posts 21
Points 290
Oh man, that is terrible! I'm assuming this is really our old "lil evil"? Post pics!
We found with the CRX there was never a problem with rotation (hence the name), so removing the front bar was a win win situation. We didn't really find an instance/surface where the lack of a front bar hurt us. The car even still slalomed well!
Left foot braking is a huge win in these cars, just ask Mike King :) I could never get the hand of it and I'm sure I paid for it in lost time.
Hope this helps,
04-09-2008, 11:57 AM |
turbohappy
Joined on 11-10-2003
Posts 543
Points 6,495
Hmmm, that means that Mike and Jason are both big on LFBing. If I can figure out how to stop hitting cones, then I plan to try to learn LFBing. One thing at a time
04-09-2008, 12:17 PM |
glagola1
Atlanta
Posts 204
Points 2,340
I don't left foot brake. I'm trying it out on the street with some success but I haven't tried it at an auto-x yet.
04-09-2008, 4:13 PM |
Crosser1
Austin, TX
Posts 196
Points 3,010
Sean,
How did it go last weekend?
Eric
04-09-2008, 10:29 PM |
accordHS22
Morgantown, WV
Posts 52
Points 940
Update: No bar is the way to go, I noticed a very big difference with the endlinks off. I am ditching the bar this weekend!
Page 1 of 3 (60 items)
1
