Fastrack "I think I'm happy"
02-21-2008, 8:28 AM |
Joe_914
Joined on 12-05-2005
Gulf Coast
Posts 540
Points 2,985
Breezed through it this morning and almost got giddy with reading tires less than 275 can be 200 pounds lighter. I will do the math later when I can spend more time.
OK 2.0L displacement, Mid engine, 275/35-15 tires. comes out to 1850 pounds ?????
02-21-2008, 10:01 AM |
modernbeat
Joined on 06-30-2004
Houston, Texas
Posts 689
Points 7,015
Re: Fastrack "I think I'm happy"
Street Mod gets to weigh less than D-Prepared! Geeez...
02-21-2008, 10:20 AM |
Joe_914
Gulf Coast
Posts 540
Points 2,985
I looked at DP when finding a place to run the 914 (aka. rolling tin can). 2200 + pounds was 200 lbs more than the car weighed with a factory window sticker.
Hence going to XP 2 years ago.
I think the 275 tire width is pure genious.
02-21-2008, 12:15 PM |
gary p
Joined on 11-23-2001
Monticello, IL, USA
Posts 2,216
Points 35,610
I like the concept but am concerned about the execution given that there seems to be no reliable corelation between the nominal width and the actual width of any given tire.
02-21-2008, 12:23 PM |
Joe_914
Gulf Coast
Posts 540
Points 2,985
Not an issue as far as I am concerned. Hoosier makes a 275/35-15. molded right on the sidewall. might be a bit shallow of me but WOOT!!!!!!!
02-21-2008, 12:33 PM |
siastuning
Joined on 03-01-2004
NorCal
Posts 49
Points 730
make to write your letters too let the SEB know that you are OFFICIALLY for the new proposal.
Vic Sias 650-704-0771
02-21-2008, 12:58 PM |
CHRISFP78
Joined on 11-15-2003
SFR
Posts 193
Points 2,625
Since the 275 is already out, why not 275 OR under ? Allows the fast CSP cars to move up for less.
02-21-2008, 1:01 PM |
Joe_914
Gulf Coast
Posts 540
Points 2,985
siastuning:make to write your letters too let the SEB know that you are OFFICIALLY for the new proposal.
I'll have to do that. Thanks Vic.
02-21-2008, 1:08 PM |
boxboy
Joined on 06-27-2001
Posts 268
Points 4,540
What do you mean Chris? The proposal is....
Add to 16.2: “Cars running tires with a rated width of 275 or less on all four wheels may compete at a minimum
weight 200 pounds less than their calculated weight per Appendix A. “
So any car with 275 or smaller tires can take the weight break. If I did my math right, that would mean Schenker could turbo his car and still only have to weigh 2040lbs. Personally, I think the weight break is on the generous side, but I'm in the minority there. In any event, the hope is that this will ease some perception issues and drive up participation in the class. Don't forget to write your letters!
-Andy M.
02-21-2008, 1:25 PM |
Joe_914
Gulf Coast
Posts 540
Points 2,985
I am as much "for" this as I was opposed to what happened a few years ago.
Looking up where and how to send my letter.
Not that I have a fighting chance against the RX-7's but Locally I am pretty sure I can crush em.
02-21-2008, 3:17 PM |
CHRISFP78
SFR
Posts 193
Points 2,625
boxboy:What do you mean Chris? The proposal is....
-Andy M.
I read the post from joe_914 at the top of the subject and it said smaller than 275. I didn't read the proposal . Lighten up dude.!
02-21-2008, 4:23 PM |
BSPC5
Joined on 02-18-2001
Oceanside CA
Posts 94
Points 1,795
CHRISFP78:I read the post from joe_914 at the top of the subject and it said smaller than 275. I didn't read the proposal . Lighten up dude.!
Chris, All he said was "What do you mean.....", and you want him to lighten up? Typical P-car driver  Personally, I am just happy the ruling SM2 RX7 powers have allowed a small concession for a change.
Gary T
02-21-2008, 4:36 PM |
rnoll98
Joined on 12-29-2003
San Diego, CA
Posts 305
Points 4,890
BSPC5: Personally, I am just happy the ruling SM2 RX7 powers have allowed a small concession for a change.
Time to sell that beater you've been driving and prep a Miata, eh Gary?
Randy Noll
02-21-2008, 6:10 PM |
CHRISFP78
SFR
Posts 193
Points 2,625
BSPC5: CHRISFP78:I read the post from joe_914 at the top of the subject and it said smaller than 275. I didn't read the proposal . Lighten up dude.!
I can say that to a Maazda driver. Plus he's a closet P-car owner. He has a Boxster in the Geerage.
It's in the P-car hand book right after the Im right everyone else is wrong rule.
02-21-2008, 6:31 PM |
Father LeadFoot
Joined on 10-10-2007
Posts 46
Points 875
Hmmm, that would put my minimum weight down around 2050 lbs, I need to hit up the scales again and see where I can take some more weight out. While I'm not sure this is the best solution, but this is good enough for now and it is better than nothing. Thanks to the board for reviewing and presenting the proposal, I hope this is enough to pull some more Miatas and Civics into the game. I'll send off a letter
Logan Murray SM2 NA Miata
02-21-2008, 6:57 PM |
ErikZ06
Joined on 03-03-2004
Austin
Posts 201
Points 1,720
BSPC5:
And did anyone not see the RX7 per rotor adder change that will add 180lbs to the 3-rotor RX7. Can you believe a former "ruling SM2 RX7 powers" actually proposed this rule?
This one probably won't pass as there are bound to be a ton of letters against this silly idea.
Erik Strelnieks 93 3-ROTOR RX7 01 Honda S2000 05 SLK 350 AMG 08 BMW 135i
02-21-2008, 7:11 PM |
Father LeadFoot
Posts 46
Points 875
I hope it doesn't get shot down...
Aren't you a few hundred pounds over your minimum weight already? And I doubt many are going to think you will be dethroned by a miata with this rule change alone.
Jreyenga
Joined on 09-03-2003
Tha West Coast!
Posts 91
Points 860
ErikZ06: BSPC5:
iirc isn't the old rule for wankel displacement 0.8L + advertised displacement. That's a neat trick considering advertised displacement is half of what it actually is. How's that 3.9L turbo treating you? :) would it be insane to just have flat minimum weights? SM: fwd: 2000lbs rwd: 2800lbs awd: 3200lbs SM2 fwd: 1600lbs rwd 2150lbs awd: 2750lbs (I pulled these numbers out of thin air so don't get mad if you disagree with what they should exactly be). Theoretically any well prepped SM car should be able to smoke the tires through 70mph, why do we care how big of a motor it takes to spin the tires?
Jim Reyenga -Certified National Hack and Car-Whore Extra-ordinare
02-21-2008, 7:59 PM |
boxboy
Posts 268
Points 4,540
A 3-rotor turbo would be 2.0 + 1.4 (FI) + 2.7 (.9 per rotor) = 6.1 effective displacement and 2820lbs. Erik would have to add about 100lbs.
-Andy M.
02-21-2008, 9:37 PM |
Father LeadFoot
Posts 46
Points 875
boxboy:
-Andy M.
Sorry Erik, I misunderstood that you were referring to the proposed Per Rotor allocation, thanks for posting that Andy. I'm a little indifferent to that proposal, I would definitely like to see AWD have a minimum of 2800-2900 lbs, but what AWD cars would classify for SM2? They'll need to do something about the EVOs, as those become more developed they'll be unstoppable.
Page 1 of 4 (63 items)
1
