Dixie Tour PAX/RTP Index Results
02-27-2008, 9:18 AM |
rtp.rick
Joined on 05-10-2001
O'Fallon, MO USA
Posts 996
Points 12,445
Attached are the Final (two-day) PAX/RTP Index results from the Dixie National Tour. I'm sure it's been said elsewhere, but the Formula Junior classes, STUL, BSPL, ESP, FSP, DP, GP, AML, CM, EM, FML, ASL, BS, GSL, HS, and STS had pretty wet conditions in the first heat on Saturday. The second heat came down to the third run, when the course got dry. Second heat was ASP, DSP, CPL, EPL, SML, DM, F125, SS, ES, FSL and STSL. If 2nd heat drivers had their act together for that third run, their Index times should be representative. The rest of Saturday and Sunday had beautiful weather.
I am having some difficulties with my "script" for individual day Results. Hopefully, Jack can get the glitches fixed and I'll be able to post those later in the week.
Congrats to Sam Strano. His driving was an exercise in perfection. Amazing to watch!!
H's & K's, Rick Ruth
02-27-2008, 12:13 PM |
Renspeed
Joined on 04-30-2005
Jacksonville, FL
Posts 410
Points 5,660
Re: Dixie Tour PAX/RTP Index Results
Thanks Rick! Speaking of results....what happened to all the tire brands bring listed? I noticed all the Bridgestone listings deleted. I'm sure they wouldn't mind having their name where it belongs...on the top of the list.... -Mike
Mike King 88 CRX Si - STS2 #99 Jacksonville, FL 2007, 2008 STS2 Solo National Champion Team Bridgestone - King Motorsports - A-Spec Racing - Renspeed
02-27-2008, 1:23 PM |
Whiplash_Motorsports
Joined on 05-22-2006
Posts 302
Points 3,980
rtp.rick:
STS ran 5th heat in the dry both days.
I live my life one cone at a time........
02-27-2008, 2:33 PM |
rtp.rick
O'Fallon, MO USA
Posts 996
Points 12,445
I typed from a printout of the the posted run/work order and the "2L" got cut off of STS2L. Thanks for the correction.
02-27-2008, 2:41 PM |
rtp.rick
O'Fallon, MO USA
Posts 996
Points 12,445
SoloTiresdotCom:
Thanks Rick!
-Mike
I'm not sure what you're looking at. The only time the tire manufacturer isn't listed is when the driver didn't choose to provide that info. (??)
02-27-2008, 2:43 PM |
Jim Z
Joined on 08-19-2001
Cincinnati, OH, USA
Posts 46
Points 1,470
Michael Snyder, #41 FS, seems to be missing from the data. His PAX time, 76.209, should be 5th on the PAX. Perhaps he was skipped because there were two 'Michael Snyder' entries?
Jim Z
02-27-2008, 2:51 PM |
rtp.rick
O'Fallon, MO USA
Posts 996
Points 12,445
Jim Z:Michael Snyder, #41 FS, seems to be missing from the data. His PAX time, 76.209, should be 5th on the PAX. Perhaps he was skipped because there were two 'Michael Snyder' entries?
I'll look into the problem. When I'm able to post the individual days, maybe I'll be able to post results that include #41 FS, Michael Snyder. I can't respond to why this happened. I've sent the problem along to my "script guru". :-)
I will say, right now, that I'm sorry for the omission. Hopefully, I'll get it fixed. :-(
02-27-2008, 2:52 PM |
Rodney
Joined on 01-16-2003
new friggin york
Posts 311
Points 4,265
i for one, would love to see sunday only pax. it was dry all day, and also i didn't suck so bad on sunday.... :)
02-28-2008, 7:39 AM |
rtp.rick
O'Fallon, MO USA
Posts 996
Points 12,445
I have replaced the "Final" file at the beginning of this thread with a revised version that includes Michael Snyder (again, sorry) and it was also created from what the SCCA is now calling "Final" results, instead of yesterday's "Preliminary" results.
I should be able to post the individual day results later today.
02-28-2008, 9:07 AM |
ddisimo
Joined on 08-26-2003
Coral Springs, FL
Posts 65
Points 1,215
rtp.rick:Attached are the Final (two-day) PAX/RTP Index results from the Dixie National Tour. I'm sure it's been said elsewhere, but the Formula Junior classes, STUL, BSPL, ESP, FSP, DP, GP, AML, CM, EM, FML, ASL, BS, GSL, HS, and STS had pretty wet conditions in the first heat on Saturday. The second heat came down to the third run, when the course got dry. Second heat was ASP, DSP, CPL, EPL, SML, DM, F125, SS, ES, FSL and STSL. If 2nd heat drivers had their act together for that third run, their Index times should be representative. The rest of Saturday and Sunday had beautiful weather.
So Rick, when are you going to fix the obvious incorrect FS PAX?  Seems FS is the 2nd fastest stock class now
Darrin
02-28-2008, 9:20 AM |
Renspeed
Jacksonville, FL
Posts 410
Points 5,660
Second fastest to CS! Rick, I was looking at the SCCA official results for the event that pops up online. It drops out a lot of the tire manufacturer listings. But...when I download the PDF file and open it, everything is there. Oh well...no worries.
Just a side note on SGMP. Times from the morning sessions are historically slower by about 1 second vs. the afternoon runs. So, take that into account when looking at the results. Temperature changes, amount of sand on the lot, and rubber laid down changes conditions greatly there. Sort of like HPT. -Mike King
02-28-2008, 9:57 AM |
129STS
Joined on 10-01-2001
Atlanta, GA
Posts 1,141
Points 16,375
SoloTiresdotCom:Just a side note on SGMP. Times from the morning sessions are historically slower by about 1 second vs. the afternoon runs. So, take that into account when looking at the results. Temperature changes, amount of sand on the lot, and rubber laid down changes conditions greatly there. Sort of like HPT. -Mike King
The temperature seems to make a large difference at SGMP. HPT... not nearly as much. Sand being the biggest issue at HPT.
02-28-2008, 10:33 AM |
rtp.rick
O'Fallon, MO USA
Posts 996
Points 12,445
SoloTiresdotCom:
-Mike King
Are you suggesting that F Stock had the best possible conditions on both days (fifth heat)?? :-)
02-28-2008, 10:36 AM |
rtp.rick
O'Fallon, MO USA
Posts 996
Points 12,445
ddisimo:
Darrin
I suppose my response to that should be, when are you going to pick up the pace?? :-)
02-28-2008, 10:48 AM |
Renspeed
Jacksonville, FL
Posts 410
Points 5,660
Out of all the heats, Heat 5 had the best conditions both days. I'm a regular attendee of Dixie events, thus my experience with that lot. -Mike
02-28-2008, 1:15 PM |
bruecksteve
Joined on 07-13-2003
Atlanta Ga
Posts 21
Points 330
I ran in Heat 4 and we had awesome conditions, even for true race slicks!
Steve Brueck '84 Daredevil F500 #140 FM My Car(s)Atlanta Region SCCA
02-28-2008, 1:58 PM |
David Lehman
Joined on 01-27-2004
Plantation, FL
Posts 1,060
Points 14,825
I was running all over the lot. In the morning I was doing it to warm up, not so much in the afternoon.
But I would have to say that I was moving much faster when I was driving the car, then when I was running around trying to warm-up and generate some heat.
PS----the urinals in the bathroom, by the concession stand that never opened, were much too close together, as I almost got splashed by a fellow competitor at the one next to me.
Trying to get faster
Page 1 of 3 (46 items)
1
