New cars for 2008
Last post 02-15-2008, 10:40 AM by sti752. 33 replies.
Page 1 of 2 (34 items)   1 2 Next >
  •  02-11-2008, 3:41 PM 284654
    New cars for 2008
    Brian's in the Exige and I've heard rumors that the STi may go to another Mississippi region member (assuming he hasn't officially defected). Trey Williams has a competitive new car and several other people have talked about buying something different for this year. But one rumor in particular really piqued my interest... something about a red car in a Prepared class.
    This is, of course, completely unsubstantiated. I leave it to you, the reader, to judge for yourself who and what this might involve.
    Mississippi Region #83 SS / #97 STU
  •  02-11-2008, 4:04 PM 284657 in reply to 284654
    Re: New cars for 2008
    Oooh...a new P car...might it be a 'Yota?
    Expect to see the old Beige 240sx out for some shakedown events before Nationals.  She's still SLOOOWWWLLY coming together, but she's getting close.
    "Thanks JT!"
    1992 Nissan 240SX
    2006 Nissan Xterra OR 4x4
  •  02-11-2008, 5:52 PM 284672 in reply to 284657
    I wish I had a new car, with a standard, and R-comps. Does that count?
    Otherwise, looks like I'll be in Street Tire with the Mustang 'vert again.
  •  02-11-2008, 9:03 PM 284700 in reply to 284657
    sooo...Lance, you might have some fender/tire clearance issues in the rear based on that picture.
  •  02-11-2008, 11:02 PM 284720 in reply to 284700
    Not exactly a new car, but more like the new kid in the region.
  •  02-11-2008, 11:36 PM 284726 in reply to 284720
    mr. haison:
    Welcome.  Always nice to have new people at events.
  •  02-11-2008, 11:51 PM 284730 in reply to 284726
    Here is the replacement for the 914... not nearly the same... but she has all the creature comforts and rides better around town. No cool factor so we might as well wail on her. I'm going to try and attend March and possibly May.
  •  02-12-2008, 12:38 AM 284737 in reply to 284700
    Yeah Brian...in that pic, all the rear weight of the car is actually sitting on the tires.  I've broken out the end grinder and some cutting wheels since I took that pic, and the rear springs compressed another full inch.  Still got a little clearancing and playing around with suspension geometry to do.  Got a question for you since you've run the wide tires and I'm assuming you've had to deal with tight fender/suspension clearances...just how close can you get to control arms and inner fenders before you have to start worrying about sidewall flex?
    Done:  300ZX brakes, 5-lug conversion, wheels/tires, LSD, solid link suspension arms, "cheap" coilovers (for now), racing seats and brackets, 5 gallon fuel cell, built motor
    To Do:  harnesses, firewall fuel cell, install motor and accessories, finish fender clearances and flares, set initial ride height and alignment, check tune and break in motor, cross fingers, pray
    "Thanks JT!"
    1992 Nissan 240SX
  •  02-12-2008, 9:36 AM 284765 in reply to 284737
    Added lots of new parts to the mustang to get it ready for the '08 season...The last thing that I have to do is mess with the front sway bar and/or sway bar end links and it will be completely FS ready...
    The only problem now is figuring out what put about a 4" long gash in the side of the driver's side front strut tube this past weekend in B'ham...Neither myself, Brian, Drew, Becker, or Bell could figure out what had happened...looks like I will be working on the car this coming weekend trying to figure out what happened so it doesnt happen again...
    Christopher R.
    Mississippi Region SCCA
    '05 Yellow Pony GT # 69 FS
  •  02-12-2008, 1:05 PM 284802 in reply to 284737
    I had some tight clearances on my rear strut housing and trailing arm. As long as I could put a piece of cardboard b/w the tire and whatever was close to it, it never presented a problem. The sidewall flex is mainly limited to the portion of the tire that is very close to the contact patch (in other words -> sidewall flex won't matter so much up near suspension components). However, tight clearances could get something stuck in there in some crazy happenstance, but I would say for a racecar that that is an acceptable risk, especially one in which so many compromises b/w tires and suspension geometry are made (i.e. ST, SP, and SM classes where the rulesets are like a maze where one thing is allowed by one rule but others make it impossible to achieve within the rules). Hope that helps.
  •  02-12-2008, 1:51 PM 284812 in reply to 284802
    Groovy.  I got about a 1/8" clearance on the lower control arm...I might grind it down a little just to be safe.  The other problem is I'm hitting the inner fender with the top of the tire under compression, so I gotta back off on the aggressiveness of my camber curve (which may not be a bad thing).
    "Thanks JT!"
    1992 Nissan 240SX
  •  02-12-2008, 2:24 PM 284818 in reply to 284812
    what class is this beast gonna be in?
  •  02-12-2008, 4:30 PM 284837 in reply to 284818
    Street Mod
    "Thanks JT!"
    1992 Nissan 240SX
  •  02-12-2008, 8:18 PM 284868 in reply to 284837
    The Mini is history.  New car coming.
  •  02-12-2008, 9:17 PM 284877 in reply to 284868
    Mr. Haison, where did you move here from? Looks like you are already hooked.
    BillyBob:
    What?! You didn't buy Brian's STi out from under James did you?
  •  02-12-2008, 9:21 PM 284879 in reply to 284877
    dboyles:
    BillyBob:
    scandal erupts...
  •  02-12-2008, 9:46 PM 284884 in reply to 284879
    It's still sitting outside and I've received no money so I guess not. Ry if you are interested I will make the same offer to you that I made to James if he doesn't buy it.
  •  02-13-2008, 8:42 AM 284926 in reply to 284884
    sti752:
    James is a rich young eng. bachelor with no kids (that I know of) to support.  He's your best bet.  Anyway I've seen you drive that car, I ain't buying it!!!!
  •  02-13-2008, 10:49 AM 284948 in reply to 284926
    BillyBob:
    So is your rule that you'll only buy a car from someone slower than you? That must severely limit your options. No wonder it took you so long to find one.
  •  02-13-2008, 1:10 PM 284967 in reply to 284948
    So Ry,  what kind of Chic car did you buy this time?  Miata, Solstice,  Z4 ????
